warpet
memory leak problem
Wed Mar 08, 2017 2:58 pm
Hi
Is there any solution or ROM version for fixing memory leak On my e7 system starts to use over 500mb of ram if phone is on for day or two so i have to restart it every day or it is useless
Dongermon
Re: memory leak problem
Mon Jun 05, 2017 9:41 pm
warpet wrote:
Hi
what rom version are you using?
have you closed all apps in your recents, if so go to settings and look at the memory tab to see which apps are using the most, then force stop the processes
