Nikolay
App save battery not working
Wed Mar 08, 2017 5:29 am
App save battery not working, can't turn off highlights the failure of the application or opens menu. After upgrading to Android 7 phone is slow, slow. Wi-Fi knocks or what not to do. After 40% charge the phone is not possible to use it, it is not possible to close and open the application to call the program saving the battery closes all apps.
Re: App save battery not working
Thu Mar 09, 2017 2:17 am
If you would like, you can return back to Android 6.0, here is the link: http://www.needrom.com/download/blackview-bv6000-4/
If you are using Win10, you may have some problem to install this, please follow the below steps:
1. Connect your phone to PC's USB
2. Open folder C:\Windows\inf
3. Right-click the file wpdmtp.inf
4. Select "Install"
