duncanh
Replacement headphones or adapter
Sun Mar 05, 2017 2:16 pm
I've hardly used the headphones which came with my BV6000 because of the poor audio qualify. However, whilst using them today (for may the 5th time in total) the wires connecting both ear cables to the junction point came apart
Rather than get a direct replacement can anyone suggest other headphones with a long connector which will fir into the recessed socket? Preferrably with te same type of ear buds so I can use my own custom fit earbuds.
Alternatively, does anyone have a link to an adapter which will allow regular headphones to be used?
Thanks
Duncan
2017-03-05 13.47.03 (Small).jpg (184.6 KiB) Viewed 11654 times
Re: Replacement headphones or adapter
Sat Mar 11, 2017 6:39 am
Thanks
Duncan
Hope the below link will help you.
https://pt.aliexpress.com/item/Original ... 824e5edbd5
duncanh
Sun Mar 12, 2017 9:11 am
Thanks. But that doesn't really help. It appears to be an original socket for the phone. First, I'd have to take apart the phone and solder in that piece. Then I'd still have the same issue with the length of the headphone jack.
What I need is a simple adapter which has an extended jack at one end (just like the original headphones) and a regular 3.5mm audio socket on the other end.
duncanh
Fri Mar 17, 2017 6:57 pm
No, that link doesn't help at all - I don't want to replace the headphone socket (and shouldn't need to on an almost new phone!).
I want a pair of headphones or an adapter with a long jack which will work in the recessed socket of the phone
tmsjaeger1
Sat Apr 15, 2017 3:31 pm
i can recommend these adaptors
https://www.amazon.de/gp/product/B01M74 ... UTF8&psc=1
or
https://www.amazon.com/FosPower-Auxilia ... 5mm+Female
they work nicely with the bv6000 even though the jack is a bit longer
cheers
Thomas
erech
Tue Jun 13, 2017 2:56 am
Have you tried any adaptors yet? I just purchased a 6000s and cannot use any of my head phones or USB charging cables. To short as you well know. I live near a small city so I'll go and look for adaptors this weekend, I know we need a tpps that's longer than "standard" audio jacks take. I looked at the suggested Amazon link and they look the same. Wondering if you've tried them. I'll post when I've got something.
Parcheval
Wed Jun 14, 2017 3:17 pm
Works very well without any problem: https://www.aliexpress.com/snapshot/0.h ... 2761594486
AaronP
Tue Jul 18, 2017 9:37 am
Would you please care to re-send the link? This one is unfortunately dead. Thanks!
Parcheval
Wed Jul 26, 2017 1:05 am
Looks like the item is not available anymore, but here's a screenshot of the product, hope this helps
lrfarro
Wed Jul 26, 2017 6:03 am
Please, you urgently need the accessories both adapters for the headsets and adapters to charge the battery of the phone.
Where can they be purchased separately ??
I will appreciate the response soon.
