Don Harry
Update 20170223
Thu Mar 02, 2017 6:36 pm
Hi admin,
are the phones with 20161025 getting the update 20170223 directly by OTA as well?
Or do the need the A 7 BETA first?
Phil
Re: Update 20170223
Thu Mar 02, 2017 7:43 pm
You need 20161216 to get the update.
Don Harry
Re: Update 20170223
Thu Mar 02, 2017 8:40 pm
Sh** - this version wont install on my phone
Petas3
Re: Update 20170223
Thu Mar 02, 2017 10:10 pm
Installed on first try no problem.
->Google Play services stop issue is resolved. System feels slightly faster to wake up. Hope other issues are resolved as well.
bvbw
Re: Update 20170223
Thu Mar 02, 2017 10:40 pm
Update installed also with first try.
Proximity sensor is less good than previous beta update.
Test with engineer mode ; before update max value was = 255, and now it's max = 160/170. :x
Calibration does not change anything.
kkleung
Re: Update 20170223
Fri Mar 03, 2017 1:26 am
Installed update 20170223, same WIFI problem as before, i.e. continuous self-rebooting in Hong Kong Science Park when WIFI is ON.
Re: Update 20170223
Fri Mar 03, 2017 3:25 am
Don Harry wrote:
Hi admin,
It is still in testing.
Re: Update 20170223
Fri Mar 03, 2017 3:36 am
Anyone who will have problem after installing Android 7.0, if you would like to return to 6.0, here is the link: http://www.needrom.com/download/blackview-bv6000-4/
kkleung
Re: Update 20170223
Fri Mar 03, 2017 5:01 am
I tried flash_tool.exe (SP_Flash_Tool_exe_Windows_v5.1648.00.000) on Windows 7 PC. Loaded the file MT6755_Android_scatter.txt. Then connect the BV6000 to a USB port of PC. Then press Download. There is no progress. Nothing changed to my phone.
Rkellyf
Re: Update 20170223
Fri Mar 03, 2017 6:34 am
Hi admin I have a problem with my bv6000 my son took it I to the pool to take pictures with his friends then with in seconds it died I was requesting for a phn replacement since I have had the phone for less than a month but the blackviews Philippines refuses. Isn't it false advertising claiming the phone is water proof when it is not?!
