bosher66
Re: blackview waranty
Thu Mar 02, 2017 5:16 pm
how long is it ???
Sat Mar 11, 2017 6:41 am
The warranty time is one year.
bosher66
Mon Mar 20, 2017 6:52 am
why wont blackview replace my phone then??
Tue Mar 21, 2017 3:34 am
Hi friend, you should go to the online shop where you bought your phone to get replacement.
The shop will contact us directly.
bosher66
Tue Mar 21, 2017 6:25 pm
The shop is not trading and more !!!!!! so blackview is my only hope !!!!!
Wed Mar 22, 2017 2:30 am
Hi friend, please help to send the link of the shop. Thanks.
bosher66
Wed Mar 22, 2017 4:59 pm
the shop was on ebay ,, that's all I can find and all I know ,, but it is your bv6000 that not working !!! so I need a replacement phone .. please
Thu Mar 23, 2017 6:54 am
Hi friend, thanks for getting in touch. Please go to the online shop where you bought your phone to get support, the shop will contact us directly.
bosher66
Thu Mar 23, 2017 7:28 am
the shop is not there any more!!!!! not trading any more !! what is so difficult for blackview to send me a new phone ,, I will send the old one back to you
gadzart
Fri Mar 24, 2017 2:36 am
I have got exactly the same problem.
I bought my phone on ebay
http://m.ebay.com.au/itm/131877610535?_mwBanner=1
I am traveling and really need my phone for my trip.
I tried to contact in skype your after sell services and... Nothing...
Nobody repplied.
Can I have an email or something to contact them?
The problem is that:
Bouton on/off doesn t work very well....or when it wants.
The battery need more than 24h to do a complete charge!! :shock: in normal power block...
One time the phone were in the water with all off the precaution that it write into the manuel instruction. I did a double check to the silicon cash (black thing to put the cable and the audio jack) but the phone took the water...
The phone has less than 6month! What happen now?
Thank you to repply because I know tht you read the message.
