kkleung
Official way to rollback to Android 6
Wed Mar 01, 2017 12:48 am
Hi admin, is there an official way to rollback to Android 6 ? I was very happy with Android 6 and the BV6000 rugged phone. But after updating to Android 7, there are issues with WIFI and the battery runs out much more quickly. I find it annoying with THE Android 7 under testing.
Re: Official way to rollback to Android 6
Wed Mar 01, 2017 2:49 am
http://www.needrom.com/download/blackview-bv6000-4/
Please follow the link to install.
kkleung
Wed Mar 01, 2017 3:31 am
I downloaded BV6000_Blackview_V01_201610251.zip and unzipped it to a folder. But I can't find FlashTools or Flash_tool.exe. Where is this tool ?
kkleung
Wed Mar 01, 2017 5:50 am
About flash_tool.exe, I searched http://www.needrom.com/download/sp-flas ... v5-1640-2/ and downloaded the version for Windows, which I'm using. Is it ok ?
alveox
Thu Mar 02, 2017 12:37 pm
follow this instruction but when i enter android 6, i always get notification "sim card removed" and both of my simcard is undetected.
man this phone is soo buggy... kinda regret buying this bv6000
kkleung
Sun Mar 05, 2017 12:39 am
Thanks admin. I successfully rolled back to Android 6. The problem of continuous self-rebooting in Hong Kong Science Park with WIFI on disappeared. Battery consumption is normal. Everything is back to normal now.
valichen
Thu Mar 09, 2017 6:21 pm
One question kkleung...
After you rolled back to 6.0 did you need to reinstall all of your previous apps and contacts etc...???
kkleung
Tue Apr 11, 2017 2:21 am
Yes, after rollback, need to re-install all the apps, contacts, bookmark, etc. Also, my phone failed to recognize my sim card, i.e. failed to make call. I performed "factory data reset" once and then it recovered. Now, my phone works fine with Android 6.0.
