BV6000 OTA 7.0 update steps
Mon Feb 27, 2017 8:31 am
Anyone who will have problem on updating the OTA 7.0, please follow the below steps:
enter into setting--about phone--wireless updating--search for the latest version.
Holger
Re: BV6000 OTA 7.0 update steps
Mon Feb 27, 2017 8:34 am
Hi admin, update is not possible!!
1. dowload zip file is ok
2. unzip file seems to be ok
3. automatic restart does not work (waiting some hours)
4. after manual restart it is booting the old system (android 6)
I tried it four times, an i try a local update with downloaded .zip file,
same result. No update
Are there some ideas what is to do???
@admin: please help me, i need support...
thanks and best regards
holger
*TBB*
Mon Feb 27, 2017 6:57 pm
Version 20161011, no update
Nikolay
Tue Feb 28, 2017 4:59 pm
Как отменить или исправить обновление андроид 7 на предыдущею версию андроид 6
