BV6000 OTA 7.0 update steps
Mon Feb 27, 2017 8:17 am
Anyone who will have problem about updating OTA 7.0 of BV6000, please follow the below steps:
Enter into setting--about phone--wireless updating--search for the latest version.
Phil
Re: BV6000 OTA 7.0 update steps
Tue Feb 28, 2017 12:42 pm
There are many people having problems when they doing exactly this like you wrote. I had the same issue once when I tried to update to 20161025. Download seem to work but the update don't. For me it helped to look for enough storage on the phone, load the batterie full and try again and again.
umerrashid
Tue Feb 28, 2017 12:49 pm
Sir,
I perform exactly the same steps as you described. but i cant able to find the update. the message appears "YOUR SYSTEM IS CURRENTLY UP TO DATE".
my current firmware is BV6000_Blackview_V01_20161011.
Kindly guide me asap.
thanks
umerrashid
Tue Feb 28, 2017 12:53 pm
Sir,
I followed exactly the same steps as you described. but i cant able to find the latest firmware i.e, android 7.0.
whenever i checked for wireless updates, its says YOUR SYSTEM IS CURRENTLY UP TO DATE.
my current firmware version is BV6000_Blackview_V01_20161011.
kindly guide me how can i get android 7 update.
thanks
ravee1010
Tue Feb 28, 2017 11:18 pm
Yes Phil is correct ....it doesnt work
Wed Mar 01, 2017 2:57 am
About BV6000 Android 7.0, it is only opened for 3000 users, and it is still in testing. If you don't receive the notice about updating for this, you can not upgrade to version 7.0.
