BV6000
Problem in Android 7 with notifications
Fri Feb 24, 2017 7:01 pm
Since i updated mi bv6000 to android 7, my notifications from Line, whatsapp, outlook, gmail... Only appears when i open the application
Any suggestion? More people with this issue?
Re: Problem in Android 7 with notifications
Mon Feb 27, 2017 8:14 am
You may not update successfully.
Please follow the steps and try again:
Enter into setting--about phone--wireless updating--search for the latest version.
wojciecha
Mon Feb 27, 2017 3:06 pm
check background task clear if these are on white list
BV6000
Tue Feb 28, 2017 9:26 am
i updated my bv6000 doing that. But i tried 3 times and all of them with the same result. without notifications, only if i open the apps...
BV6000
Tue Feb 28, 2017 9:32 am
other issue. All the times when i turn on my phone, after wrote my pin the phone don't show the desktop. I must tap the on/off button, and retap, then put the patron and after this the phone goes to desktop
Phil
Tue Feb 28, 2017 12:38 pm
try to disable background task clear for this apps
