Ivan666Heavy
Jack connector
Wed Feb 22, 2017 3:18 pm
Does the jack connector this time have more space to be able to plug in different devices or will it still be almost exclusive to blackview headphones as in the bv6000?
Hyperion1337
Re: Jack connector
Fri May 05, 2017 9:38 am
No the jack is still a problem and the blue-tooth is stuffed too.
They need to bring out a adapter : "long 4 pole 3.5mm headphone jack adapter"
or
a IP68 insert adapter for normal headphones.
Phil
Re: Jack connector
Sat May 06, 2017 8:36 pm
An headfone-cable-dapter for future phones would be nice. Or better if normal cable sizes would bit.
I could cut away a bit of my cheap cable but that will not work with all cables.
gt40emn
Re: Jack connector
Mon Jun 19, 2017 6:57 am
Solved the problem with a cabel from NIUBEE XOOOL3JDPH bought at Amazon.
girpacelli@gmail.com
Re: Jack connector
Wed Jun 21, 2017 9:41 am
I can not find the connector you could better indicate the type and link address
Re: Jack connector
Wed Jun 21, 2017 9:56 am
Here is a similar thread: viewtopic.php?f=175&t=122789#p336939
