Ivan666Heavy
Android 7/7.1
Wed Feb 22, 2017 3:01 pm
Hello Admin,
Is Android 7 or 7.1 planned for BV7000 one day ? Thanks.
Re: Android 7/7.1
Thu Feb 23, 2017 1:16 am
hello, it is Android 6.
Tomator
Re: Android 7/7.1
Fri Mar 10, 2017 12:14 pm
Dear Admin,
We know that there is Marshmallow in BV7000 Pro. We're curious if Nougat is planned for this device like it was delivered to BV6000S (but more stable and consuming less power).
BV6000 P2 BV9500Pro
Re: Android 7/7.1
Sat Mar 11, 2017 2:36 am
Tomator wrote:
Dear Admin,
Android 7 is currently not ready yet for BV7000 Pro.
Tomator
Re: Android 7/7.1
Mon Mar 20, 2017 9:38 am
Thank you, "yet" is the word we were waiting for.
BV6000 P2 BV9500Pro
adamepc
Re: Android 7/7.1
Thu Mar 30, 2017 7:07 am
Can you make sure you put release flags on the 7 build rather than test flags so GAPPS and Android Pay work correctly
Semi technical UK user
Re: Android 7/7.1
Wed Apr 12, 2017 6:54 am
Hi friend, thanks for getting in touch. We are looking for the solution about this issue. We will release the solution timely on our official forum if any update. Please keep tuned.
jmsupery
Re: Android 7/7.1
Wed May 31, 2017 2:20 pm
Hello any update on this ?
Thanks
Holefighter
Re: Android 7/7.1
Thu Jun 08, 2017 5:38 pm
OK but where is the downloadfile
JeleznyBo
Re: Android 7/7.1
Mon Jun 12, 2017 9:53 am
administrators, please upload to the official site microprogram providing for BV7000 Pro insertion to Android 7.0 Nougat with the detailed instruction as to make it most.
