zimzia
How to update android 6 20161011 for android 7
Sun Feb 19, 2017 9:22 am
How to update android 6 20161011 for android 7, my FOTA no promotion
Re: How to update android 6 20161011 for android 7
Tue Feb 28, 2017 2:50 am
It is only for 3000 users, if you don't receive this updation notice, you can not update for it. Now Android 7.0 is still in testing.
Phil
Tue Feb 28, 2017 12:57 pm
You must install 20161025 by local file to get next updates. viewtopic.php?f=144&t=101183#p284253
But android 7 is still not stable for every device.
Wed Mar 01, 2017 3:34 am
If you don't receive this updation notice, you will not have this updated, it is only for testing on 3000 users.
kup0
Wed Mar 01, 2017 5:24 am
If it is only for 3000 users then what this means?
https://m.facebook.com/story.php?story_fbid=1528779740484116&substory_index=0&id=830392660322831
kkleung
Wed Mar 01, 2017 7:10 am
Why upgrade ? My phone has upgraded to Android 7. I can't find some of the new features of Android 7.0. There is no "Multi-window view" or "Quick switch between apps". The battery drains much faster than before. Why upgrade ?
Thu Mar 02, 2017 3:20 am
It was our plan before, but while the users said Android 7 is not stable, so we are still testing it.
Thu Mar 02, 2017 3:21 am
Would you like to return to Android 6.0? Here is the link: http://www.needrom.com/download/blackview-bv6000-4/
kkleung
Thu Mar 02, 2017 7:32 am
Yes, I'll go back to Android 6.0. In fact, I like BV6000 very much as it is stable and tough. Before upgrading, the battery last for many days use even with my outting/hiking with GPS logging. It is the most stable phone that I'd used. I support Blackview, but this time I am a bit disappointed about Android 7.0.
kkleung
Thu Mar 02, 2017 7:39 am
Would there be rollback to Android 6.0 through OTA ?
