ravee1010
Downgrade to Android 6
Sun Feb 19, 2017 1:01 am
Can i follow this viewtopic.php?f=144&t=54240 and Downgrade to Android 6 if i find issues with Android 7 ??
kup0
Re: Downgrade to Android 6
Sun Feb 19, 2017 7:36 am
http://bbs.blackview.hk/viewtopic.php?f=143&t=107029
I dowgraded with this method and it worked. Only difference is how USB drivers are installed.
ravee1010
Sun Feb 19, 2017 9:23 am
@kup0 thanks for reply.
I have SP flash tool and drivers installed correctly on my windows 10.
Can you share the link of Android 6 that you downloaded to flash ??
kup0
Sun Feb 19, 2017 10:17 am
