How to flash BV2000 from PC
Fri Dec 04, 2015 11:02 am
Hello everybody ,
We have upload an tutorial video on Blackview Youtube,
you can watch to via the following web link.
https://youtu.be/tR7pU6miX0Q
Hope it can help to successfully flash the BV2000 ,
Any question, pls leave an message here, we will reply you
as soon as possible.
Best regards
Admin.
rikus
Re: How to flash BV2000 from PC
Sun Jan 03, 2016 11:29 am
which Windows version did you use? I tried it with Windows 7 and 10 64 bit and with different drivers for MTK but alays got no COM1... after the check boxes but "N/A + N/A". The switched off phone shortly appeared in the device manager and disappeared 1 second afterwards...
Thanks, Rikus
