MadCraft
Updates for the MT6737 processor
Fri Jan 27, 2017 9:40 am
I bought the phone bv6000s
build ID
BV6000S+_blackview_v01_20161009.
Will you support this party devices
Where on your site I can check the authenticity of your phone.
Re: Updates for the MT6737 processor
Thu Feb 09, 2017 8:27 am
Usually users are suggested to buy our products on our authorized stores to
get original products.
Could you tell me where you get the product?
MadCraft
Thu Feb 09, 2017 3:55 pm
I bought the phone from a private seller in Belarus
ifa66
Mon Feb 20, 2017 5:17 am
build ID
Which CPU is installed there
Will you release this phone upgrade
Why can not I use GLONASS
ifa66
Mon Feb 20, 2017 5:18 am
build ID
ifa66
Mon Feb 20, 2017 5:19 am
build ID
spinnerwind
Tue Mar 14, 2017 12:30 pm
I bought same one on AliExpress.
