Hanky
Internet by sim does not work
Wed Mar 30, 2016 12:20 pm
Internet by wifi is working, when I'm outside my home I also want to use internet but unfortunately it won't work.
Error notification: net:ERR_NAME_NOT_RESOLVED.
Error notification apps: no internet connection
When I'm using my old phone internet by sim is working, comparing BV2000 /Mobile settings/APN/internet/all settings are the same.
Looking at status settings/simcardstatus/ one setting is different: Status mobile network (connection broken using wifi) and it should change to (connected) when I'm outside using internet by sim.
Results are the same for sim#1 and sim#2.
But this setting doesnot change on the BV2000 :roll: , any solution for this :?:
A manual would be very usefull!!! ;)
Regards, Henk van Dijk, The Hague, Netherlands
shirleydowney
Re: Internet by sim does not work
Thu May 04, 2017 2:58 pm
Hanky
I feel your pain as I am having exactly the same problem now.
You posted this over a year ago, assuming you got a fix?
Please.....
Shirley, Bristol, UK
