sumskagljiva
Strange tapping noise in video that I recorded
Thu Jan 19, 2017 3:27 am
If I'm recording video and move phone (slowly or quickly) you can here tapping on the tape ...and it is very loud :x
How can I change that? Is that microfon problem or? Because when I'm waching other youtube videos or anything that isn't filmed with my phone it is ok.
HelloWorld
Re: Strange tapping noise in video that I recorded
Thu Jan 19, 2017 8:09 am
My guess is that its the autofocus making this noise!
Skyla20
Fri Jan 20, 2017 8:27 am
I receive the same noise, I informed blackview and sent them a video recording of the noise. It's very irritating.
sumskagljiva
Fri Jan 20, 2017 5:02 pm
Ok.
Is there any solution how to fix that?
Is there any one else with this problem?
Spinebreaker
Sat Jan 21, 2017 7:16 pm
Got the same problem, and Im not even filming with the stock camera app. Used Fv5 with disabled Focus and still have the same problem.
Phil
Sat Jan 21, 2017 8:32 pm
I suggest filming with the app "open camera". you can open settings > video settings > audio source and select "optimised for voice". That's not solving the issue 100% but makes it much better.
newphone
Sun Jan 22, 2017 5:29 pm
I have the same problem. It is definitely the auto focus - I have an app that scans a QR code to check lottery numbers and the click is in perfect sync with the autofocus changing.
sumskagljiva
Mon Jan 23, 2017 11:56 am
I didn't thougt of that but most likely it is,thank you
Yes this really helps
rupe
Tue Jan 24, 2017 9:03 am
In my case this tip isn't work.
sumskagljiva
Tue Jan 24, 2017 1:04 pm
I don't understand what is happening,where are my posts ??
