bvbw
Glove mode
Tue Jan 10, 2017 6:03 am
I don't see any real changement with or without glove mode (i keep original screen protection).
What is your feedback about this feature ?
Thanks
sofyancell
Re: Glove mode
Tue Jan 10, 2017 6:22 am
Thanks
Yes. Same with me. Not different.
someoneON
Re: Glove mode
Tue Jan 10, 2017 9:46 am
Same with me, but also sometimes my touchscreen would detect two touches after touch, sometimes no touches, which is very annoying when typing a message, glove mode sometimes make this better, but ometimes it makes it worse.
Is there any way to manually change the touch sensitivity?
sams
Re: Glove mode
Tue Jan 10, 2017 12:36 pm
As the option suggest it, you can use your phone with gloves.
It works great but the screen is way more sensitive so you need to deactivate it when you take off your gloves.
bvbw
Re: Glove mode
Tue Jan 10, 2017 12:55 pm
Real difference ? Did you take off screen protection ?
mobosenshi
Re: Glove mode
Tue Jan 10, 2017 10:32 pm
The Glove mode doesn't work for me either.
bvbw
Re: Glove mode
Wed Jan 11, 2017 5:54 am
Thanks for report.
Seems "glove mode" is not working for most of users ...
More feedbacks are welcome ! Maybe it could help Blackview team to fix it on Android v7 ...
Re: Glove mode
Wed Jan 11, 2017 8:21 am
Thanks
A glove mode in the mobile phone Settings, enter later can open it.
bvbw
Re: Glove mode
Wed Jan 11, 2017 10:39 am
What do you mean by "later" ? In settings, i've enabled "glove mode", that's all, ... but not difference ...
What's wrong ?
sams
Re: Glove mode
Wed Jan 11, 2017 8:36 pm
Yes, without it, I can't use the phone with my gloves.
And yes I removed the crappy plastic protection and put a tempered glass one.
