BV5000 will upgrade to Android Marshmallow
Tue Mar 29, 2016 9:52 am
Dear BV5000 users,
Happy to tell you that BV5000 will be equipped with android 6.0 system .
then you can upgrade the model to the new system via OTA upgrading .
The upgrading will take place in April , hoping you will like it.
Best regards,
Admin
Albertomx
Re: BV5000 will upgrade to Android Marshmallow
Thu Mar 31, 2016 4:35 pm
Thanks, I will wait. regards :D
Pete
Thu Mar 31, 2016 9:09 pm
Hi will this fix the incoming 4g call issue
Bagis
Sat Apr 09, 2016 9:22 am
Hi i am from Malta and I don't recive Ora updates what can I do pls?
decayedsin
Mon Apr 11, 2016 7:19 am
Will this new update include the feature of being able to set different ringtones for each one of the sim card like other phones?
Thanks.
macwaldi
Mon Apr 11, 2016 6:11 pm
First of all, many thanks for the excelent phone. After the Crown I have a BV5000 and I'm still waiting for the BV6000.
Happa to see the upgrade to marshmallow for BV5000 soon !
Thx for your investment.
Regards
MacWaldi
SnuffThePunkz
Mon Apr 11, 2016 6:57 pm
Or expanded network selection?
BorisR
Wed Apr 13, 2016 6:45 am
When will the update ??? I look forward to, really looking forward !!!
BorisR
Fri Apr 22, 2016 7:11 am
Interestingly, the delay sound will be reduced to 6 Android when connecting a MIDI keyboard.
And when it comes out? :)
steirx
Sat Apr 23, 2016 3:48 pm
Hi there, April 23rd and counting ;-)
Can you please indicate about the time frame!?
THANKS!
Robert
