ddsb
Recovery mode with problems
Thu Jan 05, 2017 12:36 am
When I put the phone in recovery mode, the recover menu does not appear and gives a message of no command, and the android appears with the belly open.
How to solve this?
Phil
Re: Recovery mode with problems
Fri Jan 06, 2017 11:04 am
You can press "power" + "lauder" to solve that problem.
sofyancell
Fri Jan 06, 2017 10:08 pm
What is lauder?
BeHa
Sat Jan 07, 2017 7:51 am
volume +
Sat Jan 07, 2017 8:17 am
How to solve this?
You can try long press the power button.
raiarii
Sat Jan 07, 2017 4:25 pm
blackview_admin wrote:
How to solve this?
hello i have the same problem....
juanpedrojaen
Sat Jan 07, 2017 11:48 pm
Yo tenía el mismo problema, algunos terminales chinos no tienen recovery.
La solución es:
1-. Instalar drivers: http://www.gizbeat.com/10576/blackview- ... p10-guide/
2.- Descargue y ejecute la última versión de SP Flash Tool: http://spflashtools.com/windows/sp-flash-tool-v5-1628
3-. En la mayoría de las webs, no tienen el autentico TWRP, descargar desde aquí: https://yadi.sk/d/rGR56jDbynEuy
4-. Seguir las instrucciones de flash que explican en el punto 1
ddsb
Mon Jan 09, 2017 5:19 pm
The problem is this when I press power and volume + to go to the recovery menu that message appears and does nothing else
drupi
Tue Jan 10, 2017 10:08 am
As Phil said after you see the picture press Power and while pressing power press vol + shortly
If you press power too long your phone will restart
ddsb
Wed Jan 11, 2017 8:39 am
This error only happens when I press power + volume up when it should enter into recovery mode, it does not enter and it gives this error
Users browsing this forum: No registered users and 10 guests
