  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
BV6000
Re: Release notes 20171011
Sun Oct 29, 2017 5:42 pm
I downloaded the 20171011 and installed it locally. It puts me on the phone that I have the 20170412. I continue with the base band p26 instead of the p27, the kernel also did not change it. I have 3.18.35
any idea?
Netsplitz
Sun Oct 29, 2017 11:08 pm
I flashed with a computer. Maybe that explains the difference? Sometimes a local flash is not effective, check under settings/about/wireless updates to see actual version. (The settings/about/version is also usually wrong)
b.mihai.89
Mon Oct 30, 2017 4:28 am
Local update did not work for me either. I have tried twice. I also tried to apply it as update from SD in recovery. and got some error.
After that i flashed from PC and all is good.
Android version shows 20170412 but Baseband should be P27 for 20171011. If not then the update was not succesfull.
BV6000
Mon Oct 30, 2017 3:47 pm
and how do I flash it from the computer? I do not need a scarlet file or something?
BV6000
Mon Oct 30, 2017 5:30 pm
:) DONE!!
Unzip, flashtool and finish =)
now it's all ok, i think
Priyanga
Tue Oct 31, 2017 7:40 am
Flashed with latest.still touch screen is too sensitive. And proximity sensor still low sensitivity.
Netsplitz
Wed Nov 01, 2017 5:36 am
Proximity Sensor can be recalibrated under engineering menu *#*#3646633#*#*
Priyanga
Wed Nov 01, 2017 7:06 am
I already recalibrated. By engineering menu and developer menu no improvement.I think its hardware fault not software issue. Black view doesn't have any answer for this issue.
Priyanga
Wed Nov 01, 2017 7:07 am
Proximity value when closed only 120.it should be over 200 to 255.
Netsplitz
Wed Nov 01, 2017 10:33 am
I remember another post on this forum, you can try to open the phone and reposition the light sensor cover. Or you should be able to request a repair.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
