Re: GPS time is wrong
Tue Aug 01, 2017 10:34 am
I will report this bug again now and hope we will get a fix one day.
bvbw
Fri Aug 04, 2017 7:54 am
Thanks, but have you really any direct relation with BV team ? or are you are like us ... just hope and waiting ...)
The GPS time is very important for an outdoor rugged phone. GPS time is used in many GPS apps and is used for special time in GPS calculators (CMS mode, etc ...) !
Is there a possibility to fix this problem with "engineer mode" ? If yes, how to ?
Edit : maybe it could fix NMEA problem in same time ...
Tue Aug 08, 2017 2:26 pm
I agree that this is a important issue. I can only report to the technicians who try to fix it and I am not able to tell you any date for the fix.
bvbw
Mon Aug 21, 2017 5:46 am
blackview_admin,
always no news from technicians about a fix ??? Seems very long for a "small bug" !!! ;)
bvbw
Fri Sep 08, 2017 4:36 pm
Technicians are sleeping ?
Fri Sep 08, 2017 4:39 pm
sorry, there are no news about that issue.
bvbw
Fri Sep 08, 2017 4:41 pm
OK, means that there will be never fix for this issue ... :evil:
bvbw
Sun Sep 10, 2017 9:29 am
If you absolutely need a correct gps time you could flash version 20161216 for the meantime, the issue does not exist in that Version.
I try to flash this version 20161216 and seems that it's not flashable because wrong scatter file found inside the ROM.
Any solution ?
Thu Sep 14, 2017 11:49 am
I flashed this so often in the past...
You could try to
- re-download the file, be sure so select the correct scatter file in the flash tool or
- try to use an other flash tool version.
Please tell me if it works or not.
bvbw
Thu Sep 14, 2017 3:50 pm
No, in version 20161216 the problem is because that when i unzip file, the scatter file is named "scatter.txt" 1 Ko ?
In all other ROMs the scatter file is named " MT6755_Android_scatter.txt" 13 Ko ...
But the only serious solution should be to get a fix for the last version ... i really don't understand why it's so difficult for devs !!!
