Valld
Re: Problems after update Androind 7.0 Rome BV6000_Blackview_V01_20161216
Fri Jan 20, 2017 10:16 am
Please see below my report of problems after the OTA update to Android 7:
"Unfortunately, Launcher3 has stopped" Nova luncher is working fine
"Weather and clock widget is not responding"
Bluetooth connectivity to my Motorolla Roadster2 is terrible, it connects and disconnects every 30-40 seconds.
The largest system font under accessibility is way too small, in android 6 it was OK
Sygic does not start at all
On the plus side I have only one think to report:
Battery lasts longer.
hersche
Fri Feb 10, 2017 8:54 pm
hello all,
this is my first post and i've to say: wow, what a phone! i hacked around the CAT B15Q-Phone which is builded in a similiar way but also far from those spec. I've done a upgrade-possibility from 4.4.2-stock to 6-cm - but the cm never worked as well as stock.
with android 7 on your phone, i'm really happy. most stuff works withouth problems for me.
i write because of a single, nasty bug in launcher3 which i didn't read here: whenever i killed a app, it disappeared from the launcher for a while. means: vlc for example goes crazy, i kill it and it disappears in the menu where i could open it. means: i couldn't open the app again.
it looks anyway a bit weird cause this seems to be a shortcut only - where is the full menu?
however, things appeared after a reboot or randomly again. my personal workaround was novalauncher, but for a ota to android 7 (which i never saw) this is may a important detail.
by the way: is there something newer than 20161216?
thx for your work!
adhy_syaef
Tue Feb 21, 2017 7:01 am
I am located in Indonesia. This morning I got an offer from the OTA update android 7, after a successful update, I got a problem "Launcher3 has stopped" and continually pop up messages appear like this, there is no clear cache menu at BV6000 mine. I eventually replace the use of "Google Now launcher" and now can run well, just not as comfortable as Launcer3 on Android version 6.
Additionally google PlayStore also had crashes, the same thing occurs also in some applications may not support android 7. until today BV6000 mine could operate well, but I still hope there is a solution to the problem on Launcher3
Виталий
Tue Feb 21, 2017 9:16 am
Hello, I have a problem after the upgrade, the application has stopped working phone when you open it vydoet error and asks to restart the application after restarting pishit occurred sboy.Pomogite how to solve this problem? And the flashlight stopped working! Androind 6 I was very comfortable, this am I not comfortable and rozochirovyvaet after eating idea how to get back to the previous one, tell me how it reap create one without losing the previous work unit?
s_kenan
Wed Feb 22, 2017 11:54 am
Before update I was using cast normally and my TV recognize it, but after update it can not recognize it as a device that doesn't supports screen mirroring (cast).
Second thing, OTG, can it be fixed or not.
How to do this OTA update.
Greetings
Kenan
