Vashta
Re: Fresh ROM ON 20160812
Sat Aug 27, 2016 4:46 pm
So, can i inject this ota or i rest in the 20160713 ota ?
mobosenshi
Sat Aug 27, 2016 10:41 pm
Is anyone else experiencing similar symptoms like Vashta? I'm reluctant to flash my phone because of his experience with the new ROM.
exciter0
Sun Aug 28, 2016 12:16 am
I flashed with flash tool and didn't faced any drama, it went fine. After unzipping the firmware I had to remove one of the .INI file so flash tool won't complain about checksum.
No idea what changed in new fw.
Vashta
Sun Aug 28, 2016 8:24 am
Um, despite blasting the phone, now the volumes and buttons / off no longer working ... I'll try to put the update .. Should I via the flash tool or or via manual OTA on the phone?
repost: I flash it via flash tool.. But it doesn't powering on ...
It just launch the charging mod when i charg it..
It powering on with adb but same problem, volume buttons and power buttons doesn't work!
mobosenshi
Sun Aug 28, 2016 10:23 pm
Admin, can you assist Vashta with his phone dilemma? I've noticed that you haven't been addressing his technical problems like others.
Mon Aug 29, 2016 10:19 am
pageoflife wrote:
Please tell me how to upgrade 20160812? Update does not come on my phone
If you failed to receive the update information , then you can use flash tools to flash the new rom we provided.
ROM and manuals were already published on forum.
Thanks !
Best regards,
Admin
Vashta
Mon Aug 29, 2016 5:46 pm
I will send my phone to the SAV because nothing work.. All the right buttons (volume and power) arren't working ect.
See you soon,
Vashta
mobosenshi
Mon Aug 29, 2016 8:51 pm
Vashta,
Keep us posted please.
Wed Aug 31, 2016 6:43 am
FredMed wrote:
Can it be installed via OTA?
All ROM we put here needs to install with flash tools , except some for local update.
mobosenshi
Thu Sep 01, 2016 3:48 pm
Admin,
I was able to update my BV6000 via Wireless Update automatically twice! I prefer this method than flashing :D
