Neville
Re: Touchscreen toooo sensittiive
Fri Mar 26, 2021 12:44 am
Does this fault only affect the first batch of phones released by Indiegogo (grey), or are the later silver or graphite versions also affected?
icedocemile
Fri Mar 26, 2021 8:49 pm
I don't have any problem with the touchscreen, pretty good. Phone bought recently through aliexpress in grey color.
I recommend to remove the plastic screen protection given with the phone as it could create extra sensitiveness.
Neville
Wed Apr 07, 2021 10:16 pm
New update appears to have finally fixed the bug...hopefully the fix will last this time...can anyone else confirm?
Thu Apr 08, 2021 2:29 am
Hello, you can update new version now.
Neville
Thu Apr 08, 2021 5:54 am
No, the update has not fully fixed the problem...screen swipes are still being interpreted as hyperlink executions...the BL6000 Pro is not fit for purpose.
Bl6000user
Thu Apr 08, 2021 9:11 pm
The new update has certainly made phantom double taps a lot less common - so far!
It wasn't a deal breaker, but was annoying, so for once Blackview seems to have made progress in fixing something!
