Qkeez
Re: New ROM On 20160713
Fri Aug 05, 2016 8:19 pm
I can't update the drivers, Windows says it has already installed the laetst drivers. Even after "Disable enforing drivers" this happens anyway. Help me :(
Vashta
Fri Aug 05, 2016 9:14 pm
I did it!
With SPflash tool V-5.1620 run as administrator.
Oh, and if you want to keep your data simply uncheck "userdata" of falshtool :)
Best regards,
Vashta
mctimo
Sat Aug 06, 2016 5:09 am
After i update my imei is gone. How i can write my imei? Because now i can not call.
styxxx
Sat Aug 06, 2016 2:49 pm
What did change? Do compass and gyro work?
edit:
I just did the upgrade, worked perfectly. I unchecked "user data" so my data won't be erased.
Gyroscope works now :) I didn't notice any other difference (except for the higher version number).
Would be nice for the future if Blackview did provide a changelog to inform us what will change with the upgrade.
mischwa
Sat Aug 06, 2016 7:49 pm
why none of my post ar published yet ?!?
Qkeez
Sun Aug 07, 2016 12:00 pm
When I connect powered off phone to the computer it connects for few seconds and then disconnects.
I also can't install drivers because Windows says that there already are installed the latest ones, even though I disabled enforcing drivers with F7 before system startup.
How to deal with this?
Mon Aug 08, 2016 7:53 am
Andrew1974 wrote:
Good morning,
I have a BV6000 with 20,160,608 software version, not without flaws, I saw that there are several subsequent updates to the one I have on my phone, the last one on 20160713. I read on the forum that there is a manual process, but I would rather upgrade over the air / FOTA. I would like to know when and if it will arrive this update or if there is a procedure to force it.
I'm awaiting confirmation. Thank you
Greetings.
Andrew
The OTA is already released.
Best regards,
Admin
Mon Aug 08, 2016 7:59 am
mobosenshi wrote:
What are the improvements & fixes on this release?
Thanks,
Juan
Hope this link will be a solution for you !
https://business.facebook.com/www.black ... 8425518583
Best regards,
Admin
Mon Aug 08, 2016 8:03 am
Mike wrote:
@Admin, can you Please provide an update file, which works WITHOUT PC flash tools? just like the previous version?
The OTA update don not need a flash via PC and it is already published.
Best regards,
Admin
dolu31
Mon Aug 08, 2016 10:36 am
Hi, i still have 20160608 version, it's not disponible by automatic update.
How can i do to install the new update ( 20160713 ) ? My pc is running windows7 and i'm in france, can you put the new ota by automatic update ? Ifno, how can i do to install it ? Is there a french manual for it ?
