İbrahim
Re: Android 10
Tue Mar 02, 2021 11:30 am
Hello, I bought 80 pro from France to Turkey Istanbul but somehow receive updates Android 10 when he takes android 10.
Re: Android 10
Wed Mar 03, 2021 4:03 am
İbrahim wrote:
Why halal a80r pro android does not trust you 10 I got a phone call from France to Turkey tray please android now 10
Hello, what is the point?
Re: Android 10
Wed Mar 03, 2021 4:05 am
A80PRO has updated to Android 10.
Igorapc
Как сменить пароль в личном кабинете в bbs.blackview.hk ??
Wed Mar 03, 2021 7:52 am
Как поменять пароль?
Может мне создать новый логин и пароль?
Нужна Ваша помощь.
Спасибо.
İbrahim
Re: Android 10
Mon Mar 08, 2021 4:30 pm
Please help me how can my A80 pro has not received android 10 update.
Re: Android 10
Tue Mar 09, 2021 3:38 am
update A80pro:https://mega.nz/file/GO4Sjajb#jQrnATVl5xx46K1cd9RgjaQ1mzMw9ArrvTrf_e1tE2Q, It just can be updated via OTA.
TemplarGR
Re: Android 10
Wed Mar 10, 2021 8:43 am
Hi! I tried to update with this file my A80 Pro phone. My current firmware version is A80Pro_EEA_M557B_V1.1_20210119V16_20210119-1803 and it is Android 9. This file from mega.nz was not shown in the file browser when i used the local file option so i turned it into a normal zip file, i pressed to upgrade with it but after reboot it had an error and didn't perform the upgrade. Perhaps i need to use another tool? The flash tool you give here on the forum seems to be for windows and i have a Linux computer so i don't know if it will work.
In any case, will the Android 10 firmware upgrade become available for download via normal wifi so i can upgrade with it normally or i can only get Android 10 by flashing it manually with the file from mega.nz?
Re: Android 10
Wed Mar 10, 2021 9:33 am
This needs to be upgraded by tools and computer via OTA.
Hello, please use our version to update again.
https://mega.nz/file/HbpTQSbT#a-N4QTxDM ... 6IHqfZ4hHc, this is the tool.
https://mega.nz/file/PG5GWbpT#gedSv_6s1 ... BJ5-yuB9F4, this is the software.
And the instrument information: https://drive.google.com/drive/folders/ ... sp=sharing
gabrielgubb
Re: Android 10
Wed Mar 10, 2021 10:02 am
Will any updates for Blackview BV6100 come soon or later?
TemplarGR
Re: Android 10
Wed Mar 10, 2021 10:59 am
Thank you for your response. It appears the software tool is available for Linux too, so i downloaded the Linux version and successfully upgraded my A80 Pro to Android 10. All seems well now. Now that i have Android 10, if a new security patch is out, will it upgrade by wifi or should i use the Flash tool again?
