Serge, good to hear from you, and thank you for the links.
I have just spent all day trying to get turn this thing into a smartphone. But I don't think its possible.
I installed your Android9 for P60 again, and that is great. But I need autostart apps for security cameras that I monitor. So I followed your link to the build.prop mods, and I did that.
And they work, and that is great! But now I have a phone that is rooted and with an unlocked bootloader, and so GooglePay will not work. I need google pay for my work also!
I have been searching for a way to mod build.prop without root, but I can't find one.
I have been searching for a way to root without unlocking bootloader, but I can't find one.
I have been searching for a way to replace the FreeManager without root, but I can't find one.
I have explored Magisk for a way to hide the unlock from GooglePay, but it seems that is no longer possible.
I thought maybe the I could modify build.prop in the image file before installation, but I can't find any way.
I don't want root, and I don't want an unlocked bootloader, is there any way to get this rom with the autostart problem fixed before I install it?
God this is sooooo frustrating!
If someone can provide me a solution I will give you €50... And Blackview should give you a job!
Please help.
Best regards,
Tom.
