  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 9
artomas
Re: New update doesn't work
Tue Apr 02, 2019 11:09 am
I had the same issue and now the update is missing:)
Tue Apr 02, 2019 11:44 am
alessandro.pagani01 wrote:
HI, same problem on BV9500 (not PRO).
Any solution without performing factory reset???
Regards,
Alessandro
Yes, waiting for the next update.
Shuffny
Wed Apr 03, 2019 6:36 am
Hello!
Today I have tried the OTA update again and successfully run. Battery 50%, SIM and SD card included.
Before: BV_BV9500_V1.0_20181026
After: BV_BV9500_V1.0_20190320_20190320-1435
BV9500 non PRO
Shuffny
Stratosphere
Wed Apr 03, 2019 11:08 am
Update's there again, and worked this time for me.
Patsix
Wed Apr 03, 2019 12:18 pm
YES…. me too !
j2shortt
Wed Apr 03, 2019 12:57 pm
So I got the update. I tried to install, but got 25% like the others in this forum. So I plugged it in as soon as I seen the progress bar get around 25% I then left it that way while I took a shower. When I came back it had successfully installed. So maybe make sure you are plugged in and just let it sit.... IDK. It worked for me.... Good luck
ZseHUN
Wed Apr 03, 2019 1:40 pm
Hi!
The new OTA upadate is successful installed on BV9500 (not PRO) phone, NO problem. :D Factory reset not needed.  8-)
Thanks the new OTA fix!
My current OTA version: BV_BV9500_V1.0_20190320
pt123456789
Wed Apr 03, 2019 2:36 pm
Update worked.
Thanks
GermanSailor
Wed Apr 03, 2019 6:48 pm
It just worked here as well after I tried for a couple of day.
I went to airplane mode after the update was downloaded. No hard reset and the micro SDCard remained in the phone.
PanopticEmu
Thu Apr 04, 2019 2:05 am
Update now working
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 9
