Ekavun
Re: Root procedure ?
Fri Mar 15, 2019 8:48 am
sams wrote:
Ekavun, you don't need to unlock the bootloader and you don't need TWRP.
You only need to use flash tool to extract and flash back your boot partition. You can't use adb to do that.
I asked blackview 4 months ago to publish the stock ROM. They never did.
I extracted the stock ROM myself and saved all update.zip as they came.
I can provide the original boot image for your ROM version (or even the Magisk patched one if you want), but you will still need to flash back the patched image with flash tool.
I would be most grateful for the rom and the patched image. Now that the boot loader is unlocked, I can flash the boot image from Fastboot. Is that not safe to do?
Thank you!
sams
Fri Mar 15, 2019 10:40 am
Priyanga wrote:
Yes  i patched the boot image with magix.when i try to flash the patch error PMT changed it must be downloaded.please selectgormat all *download scene and try again
Why didn't you said that in the first place instead of "no don't work" ????
And no, you don't have knowledge in flashing apparently.
The scatter don't match your phone partitions. Post the full version of you build (Settings > System > About phone > Wireless Update) and the scatter you used.
Priyanga
Fri Mar 15, 2019 1:55 pm
Scatter i used the same one in your post.and build no is same as yours latest.v1.4_20180920_20181130-1918
Priyanga
Fri Mar 15, 2019 3:01 pm
Screen shot
Build
sams
Fri Mar 15, 2019 3:30 pm
Did you use SP Flash Tool version 5.1828 ?
Did you select Download Only option ?
Did you uncheck every other partitions and only select boot image ?
You can try
BV6800_PRO_MT6750_V1.4_20181130-1918_scatter.zip
(1.3 KiB) Downloaded 523 times
but it should work with the first one.
Priyanga
Fri Mar 15, 2019 4:06 pm
Yes same flashtool same unticked accept boot download only.I will try this scatter and let you know.thanks
Priyanga
Fri Mar 15, 2019 5:15 pm
Im totally fedup,no luck
Priyanga
Fri Mar 15, 2019 5:17 pm
I see the end address numbers in yours and mine different.may be that is the reason.thanks
Priyanga
Fri Mar 15, 2019 5:31 pm
I tried in another pc same problem in both.
sams
Fri Mar 15, 2019 5:59 pm
The numbers are different because I use an old version of Magisk.
I don't understand why you have this message. It works perfectly on my phone, with this same scatter.
You can try to extract your full ROM : same as the boot image but size 0xE8F800000
It's very long and you need at least 60Go of free space on your drive
Then reconstruct your ROM and scatter with WwR MTK.
