Re: [TRACKED] Bv6800 pro camera unfocus
Wed Apr 10, 2019 9:22 pm
Issue has been tracked, a fix will come ;)
tintin0404
Sun Apr 14, 2019 8:57 am
with the new ROM (Update 13.04.19) it got a bit better. But the focus is till too slow.
Greetings
Mon Apr 15, 2019 8:52 pm
tintin0404 wrote:
Greetings
Please remember to perform a factory reset after each update to properly get all the fixes ;)
albertgalpin
Sun Apr 21, 2019 7:23 pm
What April update? Last patch I have is March 20, 2019.
Mon Apr 22, 2019 9:43 pm
OTA updates don't reach every user at the same time. Keep checking.
BravoGreat
Sun Apr 28, 2019 5:37 pm
blackview_admin wrote:
tintin0404 wrote:
Greetings
Yesterday, I have updated over-the-air to 20 Mar 2019 (Build no. now shows: BV6800Pro_S592_V1.1_20190320V23) and it re-booted itself after the update.  Most of the features I usually use seems to be working well, so is it necessary still to perform a factory reset?
Sun Apr 28, 2019 10:45 pm
Yes, It Is recommended aswell!
BravoGreat
Mon Apr 29, 2019 9:33 am
Noted with thanks.  Factory Reset warns that all data will be erased from the phone's internal storage, so I'll delay resetting until a problem arises or when I have backed up my data.
BravoGreat
Mon Apr 29, 2019 9:44 am
I forgot to mention that it might be better if you could cut-and-paste this sub-thread to Topic "New Update 2019_03_20" [http://bbs.blackview.hk/viewtopic.php?f=247&t=518115 as I first tried to find answers there] as this thread's topic concerns "Camera Unfocus".  Thanks.
Wed May 22, 2019 7:20 pm
Cheope wrote:
Is the issue solved?? Because after update Camera still unfocus.
I've hard reset my phone
Issue has been tracked. Tech team is working on it.
