ricoolieut
Re: [TRACKED] very very slow charging
Wed Nov 14, 2018 6:23 pm
I have also this issue with very slow charging. Itried many of different chrgers and cables, but with all of them the charging  do not exeed 400 mA. Some of other owners got charging with 1700 to 2000 mA, using standard BV cable and charger. I tried also to provide factory reset and connected with WiFi I was awaiting the update. But nothing happend. I am very disapointed with this issue. I bought this phone just because of battery and body, not because of Intercom (which PTT button is annoying). And only this one thing do not works...for me.
mvdwege
Fri Nov 16, 2018 12:11 pm
I received my 9500Pro yesterday. After first setup I factory reset it from the settings menu, but it still does not see the OTA update.
Fri Nov 16, 2018 7:49 pm
you'll have to be patient. OTA updates don't reach every user in the same time. Please check in the next days and be sure to connect to a wifi network.
stalker
Fri Nov 16, 2018 8:07 pm
Hello, can u give us a local update?
Sat Nov 17, 2018 1:20 am
Asked tech team for that.
Albert
Tue Nov 27, 2018 2:30 pm
Hi
I just purchased the bv 9500 pro and have had great difficulty charging it.
I have gone through all the forums and followed all the suggestions.
I have
 -factory reset twice
 -brought 2 new cables
 -tried different charging location
 -tried different charging units
uninstalled -(force stopped)-intercom digital
I have also installed
accubattery  giving me a
screen off charging time of 2.2%h
192mA average
and
ampere
 at 4000v gives me  a reading of between 60mA and 290ma
Any ideas people
Thanks
Albert
zkore
Wed Nov 28, 2018 2:23 pm
The people of Blackview are not giving any solution to this problem. It only indicates that the solution will be when the phone is updated via OTA, which is false. It was updated to the latest version and the problem remains.
Thu Nov 29, 2018 12:40 am
Solution will come with an update, don't worry.
magicozero
Thu Nov 29, 2018 6:52 am
Yes arrive when my phone is old and i need change it. For me is last blackview phone because have great bug.
Albert
Thu Nov 29, 2018 6:28 pm
I managed to plug into a computer (asus Chromebook ) charger.and got proper charging times
Hope it helps
