Re: The solution for sim card reading problem after firmware update
Mon Jul 11, 2016 3:04 am
adl75 wrote:
blackview_admin wrote:
drcrow777@gmail.com wrote:
Link don't work
you can try again, many other users have successfully download it and solved the problem.
Best regards,
Admin
hello for all!
maybe i wrong and i open new post.. nut i have the same problemo with "cellular receiver.." not good..change 2-3-4G... i try all..but non function..maybe the problem is only for europe..?!?
please help me.. i have just this firmware.. (v01_20160608)...??! i can try update or downgrade..if have the link..?!?
thanks for all
there is already an update on 20160630, some customers suffer a sim card reading problem.
I will check if there is a new firmware after 20160630.
Best regards,
Admin
Sapto Harsoyo
Tue Jul 12, 2016 2:41 am
I also have similar problem, after wireless update. sometime SIM card can not detected. and that's very disturbing to me is the WhatsApp messenger can be connected only for a moment. afterwards, it can not connected. The WhatsApp can be connected only for shortly, after the device restarted.
Please give me your help.
Thanks
Tue Jul 12, 2016 6:37 am
Thanks
Have you evered download the local update rom to correct this problem.
We have already give the solution, and it works fine to many customers.
Best regards,
Admin
Sapto Harsoyo
Thu Jul 14, 2016 5:04 am
I already tried to update firmware using local zip. file that you had provided, but the device inform that "signature verification failed.Installation aborted.OTA failed please power off the device to keep it in this state and file a bug report!"
What I have to do ?
osramlivio
Sun Jul 17, 2016 4:57 pm
I installed the Update BV6000_Blackview_V01_20160630 via OTA.
Now the phone is not recognizing any sim Card any more
I am Livio ITALY
dellonte frederic
Sun Jul 17, 2016 11:04 pm
Bonjour , vous ne m'avez pas répondu sur le problème de connections au réseau 2,3,4g.
Pouvez vous m'apporter une solution , je ne peux utiliser mon bv6000 normalement.
Cordialement.
frederic.dellonte@laposte.net
Mon Jul 18, 2016 6:33 am
I am Livio ITALY
you can download the rom which can be just installed via local update to solve the problem.
The download site and manual is already published, and it has helped to solve this problem
of some other users.
Best regards,
Admin
Mon Jul 18, 2016 6:44 am
What I have to do ?
It can not be used via OTA,
but follow the listed text manual to get a local update.
Best regards,
Admin
osramlivio
Mon Jul 18, 2016 8:12 pm
Thank you. My problem with sim card (TIM ITALY) has been resolved with the update
https://mega.nz/#!ul1mxIYI!9SXNzZ3SbeAz ... o_90FaDykA
killkarabill
Re: The solution for sim card reading problem after firmware update via local update
Tue Mar 14, 2017 2:22 pm
Hi there dear Admin..My bv6000 didnt recognise my sim cards..
I tried your solution to update through local storage using the zip file you provided..
It took me to a screen that had a ring and an update tray and message appeared..When the tray went to 100%,
the phone cllosed and reseted but now it only goes dim and stays there forever..No blackview logo appears at start and the phone stays there frozen..
I also tried to hard reset it using Power and +volume button but nothing happens..The phone turns on the screen stays dim and it goes off again...
I had the latest version from wireless update + adndroid 7.0 before using your file..
Looking forward for your answer..
Best regards
Users browsing this forum: No registered users and 20 guests
