ikab
Re: [TRACKED] After update 20180308 phone won't go to deep sleep
Mon May 21, 2018 12:25 pm
V0.1_20170603_20180307-1950
This is a graphic on CPU activity. Is it too little time? Interesting the low frequencies, from about 72 hours there is 1.2 sec 247 MHz, 1.5 min 390MHz, 14 sec 455MHz and 15 sec 559 MHz, these seems very short times.
Tue May 22, 2018 8:10 am
Definitely not sleeping as it should.
Remember also to perform a factory reset after updates!
ikab
Wed May 23, 2018 1:04 pm
Yes, I did it. It was a must have, because my phone became frozen some times after the update.
But now the Trusted Places menu option disappeared from the Smart Lock menu, and it also don't work in my phone.
Thu May 24, 2018 3:50 pm
Please stay on topic. Here we are talking about the weird deep sleep behaviour. Feel free to open another topic about your issue.
ikab
Fri Jun 15, 2018 7:46 am
. If this bv8000 problem was fixed, then the battery consumption would be much better, This is how the Deep Sleep state should be to work (it is a Oneplus 5T CPU working, it seems well, the mayority of the work time happen in deep sleep mode): Image
Fri Jun 15, 2018 11:54 am
Ikab in the mean time you can downgrade to firmwares 20171219, 20171227 or 2018012. Then perform a factory reset and your phone will sleep correctly.
AleP
Fri Oct 19, 2018 5:44 am
Is this normal?
Android 7 and since yesterday, the performance has worsened, the phone no longer works, help!
Here the firmware version.
Fri Oct 19, 2018 3:09 pm
Perform a factory reset and try again
joe tigercat
Sat Oct 20, 2018 11:40 am
I had this issue . A factory reset had no effect. I factory reset in the recovery menu, wiped user data, and cache, did solve the problem.
AleP
Fri Nov 09, 2018 6:18 pm
Did you solve the problem?
