  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 8
shakta
Re: [TRACKED, WORKAROUND FOUND] Pin Code Changed By Itself
Tue Jun 12, 2018 6:49 pm
blackview_admin wrote:
onurmarx wrote:
I have the same problem of pattern changing by itself (pattern for launching android OK but on homepage it says it's not the good one), and the screen capture bypass doesn't work for me : nothing happens when i push the left button.
I tried doing backups from the android recovery screen without success and can't access with USB my memory.
Is there a fix getting worked on or am i bound to have to lose my data with a hard reset ?
Thanks for the help,
Unfortunately if the Alep workaround doesn't work for you, the only solution will be an hard reset :(
Half an hour ago I became the unhappy possessor of this PIN-bug.
Right now I'm very angry with your inability to do something with it, admin, cause Alep method is not working for me, and I can't afford the hard reset at the moment!!
shakta
Tue Jun 12, 2018 6:54 pm
Couple of months before I was able to unlock phone with only use of fingerprint, and, suddenly (the word I often use here), it started to ask PIN from time to time.
There was a hint of suspicion in me that this behaviour is not "healthy", and I was right, it ended with "wrong PIN" lock of all my valuable data. F**k...
KrtekVeliky
Thu Jun 14, 2018 6:44 am
Hi, I also bought and I am very satisfied. One thing is bothering me .. I have set my phone unlock by pin or fingerprint. But twice it happened to me that he started to report that the pin was wrong. In case I restart it, I can not get it anymore. Is there a way to fix it? Thanks
Fri Jun 15, 2018 7:37 am
The bug has been already tracked and forwarded to the tech team for a fix.
Unfortunately there's nothing more i can suggest you do to except trying the Alep workaround or factory resetting your device.
As a general rule, ALWAYS make a backup of your valuable data... smartphones can get broken easily (...and also personal computers!)
KrtekVeliky
Fri Jun 15, 2018 7:57 am
I had a deposit in May, so it was not so bad. Alep workaround did not work, I had to do factory reset. Anyway, thank you :-) I have one more question. My phone offers a new version of fw, but I have to go into recovery mode. But I can not find her here. Can you help me with this? Thank you :-)
Fri Jun 15, 2018 11:52 am
We shouldn't go off-topic. Here we are talking about the PIN change issue.
Feel free to open another thread for other questions ;)
AleP
Fri Jun 15, 2018 1:34 pm
SORRY
I make a wrong, it seems that this the warkaround works only in my device or that doesn't work when this bug is verified...
Sat Jun 16, 2018 9:27 am
AleP wrote:
SORRY
I male a wrong, is seems that this trovi workshop only in my device or that doesn't work whet this bug is verified...
Didn't understand a word ahahahaah
AleP
Sat Jun 16, 2018 10:30 am
AleP wrote:
SORRY
Sorry i'm italiano and I have the correttore for the italiano language...
shakta
Tue Jun 26, 2018 7:30 am
That's right, of course, and I do backup my data, but sometimes even one day makes difference..
Back to the topic, I finally get my phone accepting PIN by rebooting couple of times. Lucky me!
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 8
Users browsing this forum: Google Adsense [Bot] and 2 guests
