pabloheras
Re: Android 8.0 Oreo update will come soon!
Sat Jan 27, 2018 3:13 pm
I would like to know if it will possible updating to android 8 without factory reset, using Flashfire, trying not to lose root and general configuration. Thanks
Chris_2017
Sat Jan 27, 2018 8:07 pm
Cool beans BV crew! You rock!
Sun Jan 28, 2018 12:54 am
I don't reccomend it at all, and don't think it will be possibile.
rocketman5004
Sun Jan 28, 2018 7:24 am
Do you think it is possible, that we get a good video stabilization? I always liked those, because your videos don't look like they were recorded with a potato, when you move a lot.
Also, I know phone companys hate it, but could you please offer a good solution to root your phone with android 8? I could really use it for some system changes, starting with small stuff like different fonts...
AdvIKAR
Sun Jan 28, 2018 8:55 am
My flash still missing and red color in photos. I really hope they will be OK in Oreo ! Please, let me have a good phone!
Regards for success
Pappmann
Sun Jan 28, 2018 1:09 pm
Don't forget to implement the multiuser/guest mode :-)
Netsplitz
Sun Jan 28, 2018 2:20 pm
Thanks Blackview! Eagerly awaiting the update.
I think everybody here would prefer less customisation and faster security patches.
rocketman5004
Sun Jan 28, 2018 8:52 pm
nanaungoo wrote:
https://f-droid.org/packages/net.sourceforge.opencamera/
please use this camera
Or you just download this camera for yourself from the Playstore. I would like features that i CAN'T just download with 2 clicks from the playstore. Like a GOOD picture/video stabilizer. Or new fonts. Or a way to root the phone. I actually like the original camera, after all the updates now a lot more. its more compact than opencamera.
but id like to be able to have a list of a whole bunch of options for the sos key. like an prefered app i instantly open or voice recording when tapping 3 times and then holding down for the third time. when you need a fast recording its better than unlocking the phone, opening the app and starting. and 3 times with hold should minimize the accidential recordings.
Also, i use an usb headset over the otg cable and it sometimes disconnects, which is annoying, but im not completely sure if its software or hardware... seems to be both. while not moving at all it nearly never happens, while it happens every minute if i move a lot.
And is it possible to set the audio port manually, so i can listen to radio over usb while the headphones are in the audiojack?
Chris_2017
Mon Jan 29, 2018 8:11 am
Ditto that, I don't give a damn about what my icons look like, this can be done via launchers anyway. I want a safe and rock solid phone that doesn't reboot!
Whip85
Wed Feb 07, 2018 2:38 am
Any ETA yet for the Android 8 update? :D
