balintmemphis
Re: [TRACKED] Background task clear always on (also if switched off) after OTA update 20180105-1104
Thu Feb 08, 2018 4:55 pm
hey guys, im not sure if this problem has anything to do with the accessibility but i experience the same problem, even after the latest 0124 update. i did factory reset several times, still nothing. BTW where do i find this background task clear option? i cant see such thing. ive tried the battery optimisation before, doesnt really work.
Fri Feb 09, 2018 8:47 am
Just go to Settings -> Background task clear
Mon Feb 26, 2018 10:15 am
Hello everyone, after update, you should always do the factory reset and reboot your phone.
Mon Mar 12, 2018 10:54 am
Guys, did latest firmware updates solve such issue?
Report back if i can close this thread and mark the issue as solved.
ghost82
Mon Mar 12, 2018 3:02 pm
No problem for me with 20180124, background task clear works as expected.
Let's wait for other feedbacks.
NB: I did not install the previous 20180105
Mike!
Fri May 04, 2018 12:41 pm
Seems fixed with latest OTA 20180307-1950.
Fri May 04, 2018 1:22 pm
Great! can anybody else confirm it?
sticzu
Fri May 04, 2018 1:31 pm
my phone found new update OTA 20180307-1950 yesterday, i hope it will solve reebot problems. flashlight is still not working when phone is locked but i cant do factory reset till sunday...
Sat May 05, 2018 2:19 pm
YOU ARE OFF TOPIC!
Mike!
Thu May 10, 2018 7:29 am
After some days I can state that for me it's definitely fixed.
Users browsing this forum: Baidu [Spider] and 5 guests
