Fredporto
Re: [TRACKED] Flashlight button in the lock screen not working anymore after 20171219 update
Sat Feb 03, 2018 2:42 pm
I have this cell for 10 dias only. after first turning on, 3 firmwares were installed. I have never seen flashlight shortcut working. I though it was Nova Laucher that somehow could block that function, but returned to launcher 3 and same problem.
Nico
Sat Feb 03, 2018 4:33 pm
Hi, i have the same problem since the last update .
kavedel
Sat Feb 03, 2018 5:26 pm
I just did the reset. The flashlight is dead. The second problem with this phone in a month of use. First the loudspeaker now the flashlight.
khaqanson
Sat Feb 03, 2018 5:30 pm
Strange!
Phone also hangs? Did you try capturing a snap?
kavedel
Sat Feb 03, 2018 5:57 pm
It was a one time thing what happened before. I had never experienced such thing before. Is the admin reading this?
Sat Feb 03, 2018 11:36 pm
rkolev wrote:
Finally had the time to flash to 20170124 using the computer, then made the factory reset and install and configure back 77 apps (half a day work). I don't see any changes. The phone is overheating as before when playing games, flashlight on lock screen is still not working. The multi-function button is useless and cannot be configured. In fact I don't see any changes in the past 2-3 firmwares. Just no comment.
kavedel wrote:
I confirm too that the flashlight isn't working on lock screen.
OK, the flashlight problem still needs to be fixed by another firmware update. Thanks for your feedback guys!
kavedel wrote:
Well, something strange just happened. Now the flashlight isn't working at all!! Battery is at 75%
Don't confuse a flashlight hardware related issue with the flashlight bug (flashlight not working ONLY when in lock screen) we are talking about in this thread.
Is your flashlight working or not in or outside the lock screen?
khaqanson
Sun Feb 04, 2018 3:45 am
Mostly a phone freezes when some apps creating a problem , the RAM becomes overloaded and phone gets freezed.so in this case kernel is set to reboot phone after a certain period of time and it can happen to any phone.The 2nd thing could be a hardware issue and 3rd could be a software issue but as I have used almost all major updates and did not face such kind of issue so I can only say if its not a hardware issue you should wait for another major update.
kavedel
Sun Feb 04, 2018 5:52 am
I wrote to this thread in the first place just to inform you that I am having the same problem with the flashlight as everyone else does and that it is not just by magic working to me. The reason I continued to write here is because my problem occurred right after I wrote here. I didn't even know I had a hardware problem since my flashlight was working fine the night before. In your opinion I should have written in an other thread but all I did was continuing the conversation I had with an other user. Summarizing for you, no my flashlight isn't working at all in any app or in the test runned by the *#87# code. I am frustrated having a second hardware problem in a rugged phone without even having dropped it or got it wet even once.
Sun Feb 04, 2018 2:32 pm
I know that hardware faults are annoying, but we must keep threads on topic (and doing it is not easy).
For your hardware problems, i suggest a replacement under warranty of the whole unit.
Feel free to open another thread about your issues! ;)
khaqanson
Mon Feb 05, 2018 12:42 pm
Dont Play With *#87# code :cry: :roll:
I just wanted to check the code *#87# and there was an option Restore Factory Settings.I wanted to see whether would it ask for my pattern or security code or not? I just touched it and phone immediately rebooted, i forced it off but when i turned it on again, still it made a factory RESET and i lost all my data.
