Matioupi
Re: UPDATE 20171219
Mon Dec 25, 2017 3:24 pm
I finally succedded reflashing the 2 IMEI codes with this tool :
http://snwritetool.com/download/sn-write-tool-v1-1728
and the usual VCOM USB drivers used for flashing ROMs
You also need the official rom to select the databases (MDDB_InfoCustomAppSrcP_MT6757P_S00_MOLY_LR11_W1630_MD_MP_V14_P14.EDB and APDB_MT6757_S01_alps-mp-n0.mp5_W17.32 files)
Of course also need the IMEI codes from the box...
Re: UPDATE 20171219
Tue Dec 26, 2017 1:34 pm
Very thanks for your feedback! ;)
Matioupi
Re: UPDATE 20171219
Tue Dec 26, 2017 5:15 pm
I noticed a mismatch between the output of uname -a command :
Linux localhost 4.4.15 #21 SMP PREEMPT Tue Dec 19 18:11:39 CST 2017 aarch64
and what is displayed in the "Device Status" page where the kernel info shows :
4.4.15 root@android #14 Thu Aug 3 15:09:39 CST 2017
is this only on my device ? what does yours shows ?
ghost82
Re: UPDATE 20171219
Tue Dec 26, 2017 6:01 pm
Mine is also as yours, except for aarch64, mine is armv8l in the uname -a output.
Matioupi
Re: UPDATE 20171219
Tue Dec 26, 2017 7:02 pm
When doing uname -a from adb shell on the PC, i got aarch64, and when doing it from a local terminal, I got armv8l.
Other info do not change....
Matioupi
Re: UPDATE 20171219
Tue Dec 26, 2017 7:37 pm
Other info...
output of top command show high cpu usage by some process :
User 29%, System 24%, IOW 0%, IRQ 0%
User 102 + Nice 0 + Sys 83 + Idle 157 + IOW 0 + IRQ 0 + SIRQ 0 = 342
  PID USER     PR  NI CPU% S  #THR     VSS     RSS PCY Name
 1370 system   20   0  14% S   122 2275576K 211796K  fg system_server
 1566 u0_a63   20   0  12% R    49 1726860K 138020K  bg com.google.android.inputmethod.latin
  367 system   12  -8  12% S    32 419292K  18704K  fg /system/bin/surfaceflinger
 9435 root     20   0   7% R     1   9088K   3236K  fg top
  232 root      0 -20   3% S     1      0K      0K  fg hps_main
  312 logd     18  -2   1% S     7  20600K   5924K  fg /system/bin/logd
    8 root     20   0   1% S     1      0K      0K  fg rcu_sched
 1614 u0_a28   20   0   1% S    47 2134688K 166036K  fg com.android.systemui
   10 root     RT   0   0% S     1      0K      0K  fg migration/0
   11 root     RT   0   0% S     1      0K      0K  fg migration/1
rocketman5004
Re: UPDATE 20171219
Wed Dec 27, 2017 3:16 am
Whip85 wrote:
I tried to do it via local update followed by a factory reset but it still shows the firmware I had. BV8000Pro-Blackview-V0.1_20170803_20171011-0929
I also have this problem and the flashing didnt work out for me. The generator mentioned in the "how to flash" PDF was missing and the one i downloaded from an other source just said "error".
Could someone maybe make an really easy(<--Important part) tutorialvideo on how to flash this phone with all links for the downloads?
Or is it possible to get this update as an OTA before the end of the year? That way I could say the updates made my phone useable for vacation in 2017. Right now my batterylife is about 1-2 days. And the way it's now, I cant take my phone anywhere where I dont have electricity nearly all the time...
Re: UPDATE 20171219
Wed Dec 27, 2017 4:03 am
Follow the tutorial, it will be easy also without a video :) . The checksum generator link has been put into the first post.
viewtopic.php?f=192&t=319505
As stated previously, OTA delivery time can't be predicted.
Matioupi
Re: UPDATE 20171219
Wed Dec 27, 2017 10:01 am
any comments on the CPU levels at idle that are way higher than they should be ?
