Oakensang
Re: Phone reboots (crashes) at night, startup sound will wake up everybody
Fri Nov 10, 2017 9:48 am
I have the same problem, since I reveived the phone 2 Month ago the phone keeps restarting randomly. There is no causal connection between activties and reboots. The update to the current rom brought no improvement. In another post was a link between battery life and reboots mentioned I agree that my phone has never run longer than 24 hours and keeps losing battery level in a very fast way without heavy usage.
mambociccio
Fri Nov 10, 2017 1:07 pm
dhamokk wrote:
I also got a few sudden reboots, but not very often. It seems, that not the whole System is rebooted, since I didn't have to type in the pin numbers for the SIM cards. Last one was today, I just put in the audio cable from my car into the phone, as it rebooted.
//edit
Additionally, the fingerprint sensor is not working right now, I have to reboot the phone again to make it work.
Factory reset and you will stop the crash reboots
Sorry for the english
Kawi
Sat Nov 11, 2017 8:03 am
I have the same issue, just received my Blackview 8000pro and installed the last update ending 0929 but the phone switch off on its own, once or twice a day. Please fix it in the shortest time, because it's an amazing phone but this is very annoying and bad.
Thank you.
kotta
Sat Nov 11, 2017 2:16 pm
Yep i have the same issue. The phone just restart without doing anything on it.
Regards
Mino
Mon Nov 13, 2017 10:00 am
I have same problem, after new update :(
Wahut
Mon Nov 13, 2017 11:03 am
My phone is doing the same but only about once a week. Would actually be a little angry if it happened daily. Had several Samsung phones before this one and never had theses issues. I hope the Devs can fix it very soon :)
ivanot
Tue Nov 14, 2017 3:41 pm
Same issue for me, but it seem I've solved disabling DuraSpeed.
Will stay tuned.
Nik92
Tue Nov 14, 2017 9:21 pm
No, disabling DuraSpeed won't solve the problem. I have it disabled for one month now - but have same issues.
melik
Wed Nov 15, 2017 3:03 pm
I had also few Reboots a day. After I removed "signal" everything works fine. Ok, almost fine. I had one Reboot in the last month.
Henryk
Wed Nov 15, 2017 3:24 pm
I have the same problem, my BV8000 reboot ramdomly, please do anything
Users browsing this forum: Google Adsense [Bot] and 2 guests
