oaimng
Re: Jack Adapter [ORDER NOW] !
Thu Nov 02, 2017 10:26 am
Alternative solution for the jack problem:
https://youtu.be/GEyFid0HohE
Phil
Thu Nov 02, 2017 4:02 pm
I am also interested to buy one adapter for 10€ (or maybe two but not for the double price).
Aeron
Thu Nov 02, 2017 7:05 pm
Do as you please, but keep in mind that you loose the warranty of the phone and the headset by doing that.
This is a (bad, if you ask me) mod more than a solution.
I've ordered the 17mm jacks today. I'll post here when they arrive and each test of the process.
By the way, I'll make a batch of 25 pcs, not more (takes too long).
Luke wrote:
Unfortunately it's not a real solution to the problem. And 10 EUR is not a cheap price (but I understand if you're making it by hand).
I'd consider the problem to be solved if one could buy an adapter.
It should be given with the phone, however.
I kinda agree with you. That is the only thing I found to use any headset with my phone that does not require a modification of the phone or headset, though.
fabriprodrive wrote:
Hi. If the adapter comes out as the one in the photo, I'm interested
It should look like that. Design may change slightly, because I had some trouble with the first one (no the easiest to put together), but it should be very similar.
I updated the first post !
jman0
Thu Nov 09, 2017 2:02 pm
Hi, I'd like to order 3 of them. I'm a new user here and can't send private messages yet, so I hope you see my post :D
I ordered another adapter someone recommended here (from Amazon) but it doesn't work, unless you do the knife trick, something I won't do. Quickest way ever to void a warranty.
kotta
Sat Nov 11, 2017 2:15 pm
Please let me know which jack plug I need to buy, because i have a beast headphone and it cannot be used now.
Thanks for the answers.
kotta
Sat Nov 11, 2017 5:46 pm
Hi
I'm interested too. Please let me know what i need to buy.
Thx
jman0
Tue Nov 14, 2017 7:29 am
Hi, I'm also very interested. I'd like to order three. Thanks.
tito.cascara
Sat Nov 18, 2017 12:20 pm
Hello, I'd like to order one adapter, thanx in advance!
Aeron
Mon Nov 20, 2017 10:11 am
Hello there !
I've added you both to the list. Please don't send PM to order !
I don't get notifications for PM, and I check this topic regularly. Just be patient, I'll see you request sooner or later.
In other news, parts were shipped a couple weeks ago, and should arrive within a month tops.
I may have time by the end of the year to make an ship a reasonable batch. Keep tuned !
Aeron
fabriprodrive
Mon Nov 20, 2017 5:54 pm
Ok, I definately confirm my interest.
