nonobike
Re: Blackview 8000 pro + Waze = CRASH
Thu Aug 24, 2017 4:30 pm
Updated 20170822
EVERYTHING IS WORKING !! Thanks to the BW team
IvanK
Fri Aug 25, 2017 5:49 am
Thanks a lot. Last update fixed the problem.
lordnash
Fri Aug 25, 2017 8:20 am
Great job guys :D
Thx to the BW team.
Gregory
Fri Aug 25, 2017 8:29 am
Hello, since yesterday's update, waze works.
Master-Peter
Fri Aug 25, 2017 8:41 am
That sounds great! Thank you Blackview. :mrgreen:
elrik1090
Fri Aug 25, 2017 2:52 pm
Work now with the last update, thanks you blackview for listening your client !
Canute
Fri Aug 25, 2017 5:10 pm
Fix !!!
Thanks for your work !!! You're serious
Sun Aug 27, 2017 10:55 am
Thanks for your feedback!
hykandrade
Re: Blackview 8000 pro + Waze = CRASH (Solved)
Mon Aug 28, 2017 11:59 am
:D :lol: :D
finally it's working perfectly here
