richardyap001
Re: [SOLVED] BV8000 fingerprint not working
Tue Dec 12, 2017 11:10 am
I have the same problem too. The fingerprint scanner refused to recognize and I am locked out from most of my apps. I tried contacting the after sales contact posted on Blackview website. They have not been responsive. Anyone figure out the way to unlock the Security without fingerprint and fix the scanner problem? Thanks
Tue Dec 12, 2017 11:43 pm
Please upgrade to the latest firmware, perform a factory reset and report back.
kavedel
Wed Jan 17, 2018 9:37 am
I think I have an issue with the fingerprint sensor too. I have 20171227 (flashed and OTAs and factory resets after each update) and twice in the last 5 days the sensor seems dead. Not only it will not unlock the phone but it seems that also the settings from the menus disappear completely as if the phone don't have one, but after a restart it works fine and the settings are back having the fingerprints saved working.
jman0
Wed Jan 17, 2018 9:49 am
That also happened to me once or twice. but it happened right after the phone suffered a soft reboot (when it doesn't completely reboot, just the UI). I didn't pay much attention to it, since it was rare and a proper reboot would solve it.
Wed Jan 17, 2018 10:14 am
Did you directly flash your device to the 20171227 version?
kavedel
Wed Jan 17, 2018 10:35 am
I flashed it to 20171219 and then by OTA the 20171227. Factory reset both times. The phone was updated the first day I got it.
Wed Jan 17, 2018 11:37 am
Can you flash to the 20171227 version and report back? I know that could be annoying, but it seems that doing only the OTA update led to strange issues.
kavedel
Wed Jan 17, 2018 11:49 am
I'll give it a try and will tell you if the issue returns.
kavedel
Sun Jan 21, 2018 4:55 pm
So, I have news. After a flash to 20171227 and about 68 hours on, with 30% battery I had a software restart (phone did not ask for pin on sims) and the fingerprint sensor is not working.
Sun Jan 21, 2018 5:22 pm
Does the fingerprint sensor stop working only after a sudden reboot or it happens also in other circumstances?
