  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 9
Bossman
Re: BV 8000 Pro Problems
Tue Jul 25, 2017 1:15 am
Hi I recently got the BV8000 pro, and it seems to restart out of nowhere every few minutes.
I have tried factory resetting it but still had no luck.
Could you please suggest the next best course of action?
Bulwa1337
Sat Jul 29, 2017 12:13 pm
I have exactly the same problem. Brand new phone, restarts every couple of minutes.
Alex21011982
Re: BV 8000 Pro Problems- Видеозапись
Sat Jul 29, 2017 11:09 pm
Почему камера записывает видео с моно звуком??? слышно только в одном наушнике!!!
Mon Jul 31, 2017 11:45 pm
What rom version are you using?
if you're on the latest try downgrading, if the problems persists please tell us
starvirgo
Tue Aug 01, 2017 1:11 pm
I have just purchased a BV8000 pro mobile & my experience is as below:
1.0 There is some time lag experienced while scrolling messages (SMS) and call logs, any reason?
2.0 It seems that the earphone jack is a bit too deep & probably it needs the earphone with longer pin.
3.0 The earphone quality is not so good & I'm not able to use my other (Sony) earphone; so can you recommend / send me a better quality earphone for this mobile, preferably in Gold color.
4.0 and the last thing, the phone is a bit too heavy!!
regards
Naveen
Bossman
Tue Aug 01, 2017 11:50 pm
I tried both, the latest and the previous. The problem persists.
CVirus
Wed Aug 02, 2017 11:47 am
I'm also suffering from bluetooth and WiFi connectivity problems .. bluetooth randomly disconnects and also wifi.
The return/back button doesn't always work!
Also, anyone else noticed that gmail almost never syncs automatically? I stopped receiving notifications for my emails! I'm sure it's not a configuration problem from my side!
ft1980
Wed Aug 02, 2017 5:36 pm
For the Admin
Hello, today i have received my BV8000 PRO, after installation of the tow sim and ad sd card, and add of some app, when i try to restart the BV8000 it freeze with the logo "Blackview" on a black screen and the logo "powered by android".
I try several time, with the same results, pleas give me some anwers.
Bye.
Fabio.
CVirus
Wed Aug 02, 2017 11:27 pm
Another very serious problem after I did the firmware upgrade is that the alarms never go off if the phone' screen is off!! I almost missed work the past 2 days thinking everytime that I forgot to set my alarm.. Till I did a manual test to confirm the issue.. Anyone else?
CVirus
Thu Aug 03, 2017 9:28 am
I'm using "sleep as android" alarm app and it was working before the update.. Please advise!
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • 9
