Re: [USEFUL] Compatible headphones adapters
Sun May 20, 2018 9:13 am
popfish wrote:
hi , im new bv8000 pro user from malaysia , looking  long headphone jack  :cry:  due unable plug from my other headset.
adapter
Long headPhone Jack
Audio Splitter, 3.5mm Speaker and Headphone Splitter Adapter
cable
niubee 4 Pole auf 3 Pole AUX 3,5-mm
any idea get this item :( ? seem like item as above not deliver asia area.
appreciate help advice
This should work, but you'll have to solder them:
https://it.aliexpress.com/item/4Pcs-Cop ... autifyAB=0
popfish
Mon May 21, 2018 8:28 am
blackview_admin wrote:
adapter
Long headPhone Jack
cable
thanks information,
I prefere headphone jack if is available get purchase into asean site.
LongJack1
LongJack2
I try look for adapter  ( seems like vention USB audio)
for music/gaming lover. is this compatible type-c usb audio ?
USB-SoundBlaster
Tue May 22, 2018 8:24 am
adapter
Long headPhone Jack
cable
thanks information,
LongJack1
LongJack2
USB-SoundBlaster
The usb audio adapter you linked seems to be compatible. You can use it withe the OTG cable adapter wich came with your phone ;)
ziopix
Re: Headphone
Thu May 24, 2018 10:30 am
bvbw wrote:
This one is more small and simple and works fine !
https://www.amazon.fr/FosPower-Concepti ... 9VVZJ&th=1
I bought this one.. but doesn't work on the BV 8000 Pro, still to short
On which phone did you use it?
Thanks
flashn00b
Fri May 25, 2018 2:09 am
Signing on from Canada. Looks like all of the options mentioned here are either sold out, don't ship to canada or both.
popfish
Re: Headphone
Fri May 25, 2018 3:10 am
Thanks
seems like you need straight through 17mm jack as my undertanding, ( self soldering if unable bought actual adapter :(
4 Pole 3.5mm Stereo Audio Female Jack Socket Solder Connector DIY
maybe i need self  DIY bought tools soldering   male to female headphone jack :cry:
bvbw
Sat May 26, 2018 3:42 pm
Works fine on BV6000. Seems there's a small difference with BV8000 ...
markus.benjamin
Thu Aug 02, 2018 3:57 pm
hi,
is there any currently available adapter product that requires no soldering?
Thu Aug 02, 2018 10:00 pm
markus.benjamin wrote:
hi,
Where are you from?
thelastfoiter
Sat Aug 18, 2018 5:00 am
I'm still waiting on an adapter as well... USA
