Holefighter
Re: COULD NOT RUN ON ROOTED DEVICE
Mon Jun 26, 2017 10:26 am
Try the new rom, its no certified and samsung smart home runs without issues.
Derk
Mon Jun 26, 2017 3:25 pm
May be some apps now run without issues, but the ROM still is not free of "test-keys" labelling, so some users might still run into the problem of identification as rooted device...
ro.build.description=full_hct6750_66_n-user 7.0 NRD90M 1498138514 test-keys
ro.build.fingerprint=Blackview/BV7000_Pro/BV7000_Pro:7.0/NRD90M/1493011204:user/release-keys
Holefighter
Mon Jun 26, 2017 3:51 pm
MH... If you give me a APP i test it if you want
Derk
Mon Jun 26, 2017 5:41 pm
Personally I don't have issues with this as I know how to bypass this, but it still remains lazy development not following Android standard procedures...
It was said that the May release should fix it, then the next release, but you see, it's still there in some parts. And this is an issue kjnown since more than 10 months, just too lazy to learn how to do things right.
In my former company - Europes largest software company - the responsible developers would have been fired after two anouncements of bad work. Or sent to clean the toilets or something else where they can't harm the companys reputation as this software with Kindergarden errors does to Blackview.
Dongermon
Mon Jun 26, 2017 6:03 pm
so you worked for SAP?
Derk
Sat Jul 01, 2017 3:28 am
Correct...
Enekii
Wed Jul 05, 2017 6:32 pm
better question how did you get it to root,
Derk
Fri Jul 07, 2017 1:38 am
The issue is that the device is seen as rooted due to lazy developers but is not rooted.
And this issue exists since looooong, not easy for some of the users.
nedo
Sun Jul 16, 2017 2:43 pm
I was thinking of getting a NEL coil for my AT Pro, but worry about the weight even with the easy swing harness.
ВїWhere did you get your carbon shaft please?
HH
Гадание Таро Кельтский крест
Mon Jul 17, 2017 2:46 am
HH
Only the BV7000pro of pre-install Android 7.0 can flash this Rom to fix this rooted problem, (if your phone upgraded from 6.0 to 7.0, you must not do this).
BV7000_PRO_Blackview_20170712 https://mega.nz/#!NXwlkSKa!1aABB4ATM9US ... OcKYtOqeng
