bvbw
Re: GPS time is wrong
Thu Jul 20, 2017 7:49 am
blackview_admin, thanks
before flashing 20161216, i would like to know why when i unzip file, the scatter file is "scatter.txt" 1 Ko ?
In other ROMs the file is " MT6755_Android_scatter.txt" 13 Ko ...
Thanks for complete answer, please.
Thu Jul 20, 2017 9:18 am
Sorry, I can not tell you. But I once tried flashing and it worked for me.
bvbw
Thu Jul 20, 2017 9:23 am
Answer is important to install TWRP recovery ...
Thu Jul 20, 2017 9:26 am
I have no other file that I could give you. Hope it works for you.
pecor
Fri Jul 21, 2017 12:46 pm
Same problem with P2 device !
-> 1h less than display time :-(
Android 7
Build = P2_Blackview_20170619
bvbw
Fri Jul 21, 2017 3:12 pm
Why Blackview devs are not able to fix an as simple bug like wrong GPS time ???
Parcheval
Wed Jul 26, 2017 12:45 am
Did you try to update to the latest firmware, 20170708 ?
bvbw
Wed Jul 26, 2017 4:26 am
@Parcheval, please
I know what and why i ask this ... ;) Thanks
Parcheval
Wed Jul 26, 2017 6:06 pm
You're not the only one on this forum, pecor for example is still using 20170619...
bvbw
Wed Jul 26, 2017 7:58 pm
Before posting, please read all topics about this problem : admin say that problem is for some countries ... so it need update to fix it !
20170619 ... where do you find this ROM for BV6000 ? ;)
