Holefighter
Re: Flash ROM of BV7000_PRO_Blackview_20170523
Thu Jun 08, 2017 10:00 am
Yes i did. I enable usbdebugging then shut it down and plug it in to the pc immidently the programm say (when i start) 100% download an then i have to wait 2-5 minutes then the message came.
But i always get a message that the device is not ready in the device manager...
peluso
Thu Jun 08, 2017 2:36 pm
I first click on download, and then connect the BV7000, the process starts and ends regularly.
I recommend changing USB port, possibly also changing PCs.
Using Flash Tools 5.1720.00, I hope to help you.
Holefighter
Thu Jun 08, 2017 3:02 pm
OK i try it now. I will let you know
shahardemos
Tue Jun 27, 2017 7:23 am
Hi, I upgraded today 2 BV7000 Pro devices to Nougat. Using windows 7 64bit PC, installation was straight forward. The only issue I had is that it won't identify BV7000 Pro with firmware from 24 March. Only after I upgraded to April 11th version, SP Flash tool identified it in Download mode.
Nougat feels much better and faster. Thanks
chev7
Tue Jul 11, 2017 12:43 pm
Hi. Please reload firmware for BV7000_PRO_Blackview_20170523. Your link does not work on your forum anymore. Thank you
Tue Jul 25, 2017 2:04 pm
I will request a new upload.
grAwp
Fri Sep 22, 2017 8:05 am
How difference is between this ROM 20170523 and ROM 20170411 ? What was fixed ?
Thank you.
Fri Sep 22, 2017 1:44 pm
Please use the latest Version for your device: viewtopic.php?f=176&t=191529&p=376561#p376561
grAwp
Sat Sep 23, 2017 7:42 am
I have on my BV7000 pro this ROM 20170411 and I am very happy because it works very well. Phone is stable with no issues. Everything works great.
So I want to know what is the difference between ROM 20170411 and ROM 20170523.
Thank you
Sharazar
Fri Oct 06, 2017 11:21 am
I also receive the following error message each time I try to flash my device.
ERROR : STATUS_DEVICE_CTRL_EXCEPTION (0XC0050001)
In a previous post you guys asked if the guy with the same problem had enabled USB downloading.
Is this a setting on the phone or the PC?
Users browsing this forum: Baidu [Spider] and 3 guests
