Tue May 23, 2017 1:44 pm
by dee-san » mar 23 mai 2017 07h58
"Are you kidding me?!
It's so unresponsive and lagging, it's nearly unusable!"
No, I'm not joking. Personally, whatever the update, I make a backup of my data and applications and then I systematically do a factory reset. This helps to solve some bugs. I may have been lucky when buying the BV6000, but until now no major problems with the software.
by Parcheval » mar 23 mai 2017 09h11
"Gerard mentioned that after Factory Reset it helped him, I personally didn't have to do so since it worked straight away, but can understand no one likes Factory Reset in order not to loose everything, so can only suggest to perform several times the Local Update with the same firmware and/or switch off/on the phone several times to see if it helps..."
"Parceval" is right, we lose everything. But after the update, just restore the backups and redo all its settings. So I can not advise anyone. Nevertheless, the "factory reset" is a habit to be taken and which solves many problems. At first it's tedious, after that becomes a routine.
Good luck to all those who have problems with their BV6000.
