Alain 76
Re: Issue after update 20170414
Fri Apr 21, 2017 11:48 am
Ouh la la, when I watch the battery consumption of my blackview Bv6000
compared to "The Saint", its screen consumes about 17% and mine
consumes 79%, there would not be a problem ?????
9std9
Fri Apr 21, 2017 11:54 am
Don Harry wrote:
now it`s very difficult to use the HOME, BACK and MENUE buttons.
The are no more sensitive, its nececary to tip them very hard some times.
CORRECTION of version: Issue after update 20170414
Hello!
You look glove mode turn off.
My case is turned on glove mode by update.
Parcheval
Fri Apr 21, 2017 4:26 pm
The_Saint wrote:
After update to 20170414 I can see even higher battery performance, see the screens before and after updating https://goo.gl/photos/p95hT9eSyLeLZJSM8
Two SIM cards still working, wi-fi & bluetooth non-stop on, facebook, twitter, etc., but without gaming. Before update working time ca. 3 days or a bit more and after update more than 4 days (two first screens).
I believe you, but was 100% this morning, now only 42% and just 7h remaining... Only 1 SIM and WiFi...
If I let a non-white listed app open, it doesn't get shut so I think the problem is around there, Doze Mode not working anymore either... Restarting the phone doesn't help.
Did you perform any reset after the upgrade? Strange that power consumption was pretty good for me up to 20170223...
The_Saint
Fri Apr 21, 2017 5:13 pm
No, neither reset nor back to factory settings. Just simple update via OTA without any extra actions after that.
damingara
Sat Apr 22, 2017 9:32 am
updated to 20170414 and also feeeling the softwarebuttons (home, back, menu) very hard tu use.
This should be fixed in future update please.
Davros84
Sat Apr 22, 2017 1:39 pm
Is there something I'm missing? I never get updates
mauron
Sat Apr 22, 2017 6:11 pm
Not even me
Parcheval
Sat Apr 22, 2017 6:26 pm
Parcheval wrote:
Since the update to 20170414, I'm experiencing big increased power consumption, which results in decreased stand-by time.
I think it is due to the fact that:
- non white-listed app are no more automatically shut down
- the Doze Mode feature (When your screen is off, your phone should burn less battery clearing the background tasks) seems not to work anymore
Issues solved after a Factory Reset (and corresponding loss of data and app...), battery usage and saving power features working again
h0w4rd
Sat Apr 22, 2017 10:24 pm
Factory reset... No no not again! I don't want to do it. I rather throw it from the window.
Davros84
Sun Apr 23, 2017 12:29 am
I currently have v01_20161216 and have never had a FOTA update. Is there a trick or something i'm missing?
